Cabin Air Temperature Sensor - 01 V70 XC
Old Mar 18, 2018 | 12:17 PM
tony1963's Avatar
Default Cabin Air Temperature Sensor - 01 V70 XC
I've never had an issue like this one. I did a little checking on the climate control unit. The temperature sensor was full of lint and debris so I cleaned that out. Removed the unit from the dash and removed the fan from the back that draws the air over the sensor.
The data on the temperature sensor before the cleaning was -27 degrees F and after is -40 degrees F. I suspect that the sensor is broken.
The sensor appears to be an integrated part of the climate control unit. Has anyone ever changed the sensor itself?
andysvolvo
Sep 10, 2012 07:52 AM
rnlmorris
Aug 29, 2010 07:46 PM
Maruccio
Jun 9, 2008 05:48 PM
PE**2
Mar 14, 2008 10:30 AM
deathbots
Dec 27, 2007 09:08 AM
