CEM Removal & CEM Instalation in an 04 XC70
Old Aug 5, 2013 | 09:23 AM
JenniferXC70's Avatar
Default CEM Removal & CEM Instalation in an 04 XC70
Hello-
I have been put in charge of finding information about the removal of my CEM in my 04 XC70. I cant find any information or instructions on how to properly do this, are there special tools needed ect... Also, will I be able too look at the CEM and know if there are loose connections or burnt wires? Ive been having issues with the car "slamming," interior lights shutting off, srs airbag warnings, left door ajar warnings, brake failure warnings... people keep saying CEM or DIM. Starting with CEM. Since I have already tested the alternator and replaced the battery.
Thank you in advance!
Old Aug 5, 2013 | 01:21 PM
ES6T's Avatar
Are you getting a rebuilt CEM? They are programmed to the car you know. And also, its a pretty expensive guess.
Old Aug 6, 2013 | 02:26 PM
Yes, I am purchasing a rebuilt CEM from XeMODeX for $550, I am sending them my old one for them to program.
Central Electronic Module (CEM) for Volvo - Xemodex Inc. | Xemodex Inc.
After doing a lot of research on the specific symptoms I've been having a lot of people say CEM, also, pulling fuse #32 (if I remember correctly) and putting it back in, seems to reset everything. (CEM fuse) XeMODeX says that they sell 2-3 CEM's a day for XC70's. Honestly I have been driving the car for two years not knowing if/when its going to act up. I bought it because it was supposed to be safe. Now I can't drive it for long distances, and forget about driving it when its over 80 degrees. (can you tell I'm furious with my car?) So I figure its a pretty educated guess and Ill take the risk for $550.
Old Aug 6, 2013 | 04:20 PM
OK, CEM is out. We took a hair dryer to heat it up and see if we could make the problem happen. It did! Boxing it up and shipping it out tomorrow.
Old Aug 20, 2013 | 10:26 PM
MoneypitC70's Avatar
Please post a procedure and a result from the new unit. I have similar symtpoms in my car
Old May 24, 2021 | 01:41 AM
Volvo Woes's Avatar
Hi Jennifer,
What happened after this, did it work??
Old Mar 26, 2022 | 12:26 PM
Kevin Whitton's Avatar
I sent my CEM (2005 S40) to Xemodex, they said it was ok but suggested I get a new refurbished/reprogrammed one for $600 so I did. The new one wasn't in as good a shape as the one I sent in and they didn't supply the 2 very important screws to reinstall it (mine had them but they didn't move them over). Anyway, I reinstalled it to test it out - no difference. More wasted $$. I emailed them a few times about the screws and other questions. Never any answer about the screws. I submitted a warranty application. It's still ongoing. They want a Volvo computerized vida test done but the car is immobile and I'm not about to have it towed to Volvo because the dealership caused me a small fortune already and ripped me off, I'm sure. This probably doesn't help you but I felt people show know
Old Oct 25, 2022 | 10:46 PM
erickmitchell44's Avatar
After reading the suggestions on this forum, I have tried replacing fuses before going the expensive way of replacing the CEM. Turned out a 10 amp fuse located in the driver compartment (position 27) fixed the issue. After replacing that fuse everything started working correctly again.
Mi6on
1998-2000 model year XC70
Jun 29, 2013 03:17 PM
teising
Oct 29, 2009 05:08 AM
V50 Dom
Oct 13, 2009 01:59 PM
huzzsaba
Apr 2, 2009 05:35 PM
GaryBrad
Aug 17, 2007 06:49 AM
