ECM-439C Fuel Tank System Leak, Large leak
Old May 3, 2012 | 07:28 PM
2008XC70's Avatar
Default ECM-439C Fuel Tank System Leak, Large leak
Hi all,
Can't seem to shake this pesky ECM-439C code that I've had on a 2005 XC70 for a while now. Says Fuel Tank System Leak, Large leak. Check engine light on of course.
I have replaced the gas cap with a new Volvo gas cap. I verified that the latest software is up to date with DiCE as far as the control module (which makes it not as sensitive to leaks).
When I go to perform a "quick test tank system" in VIDA, I get an error message. The key is in position 2 as required, but the test will not initiate. Could this be a faulty leak detection pump?
This vehicle is emission code 2.
Thanks in advance for your help!
Old Dec 20, 2017 | 03:07 PM
cantabrian's Avatar
Hi, Did you ever figure out what the problem was? I have a 404c code (Fuel tank system, major leak). The only real symptom is lower fuel emission. I don't smell fuel outside the car. Maybe my problem is the same as yours was?
newyan
Nov 2, 2022 07:06 AM
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
capsfan69
Mar 4, 2010 07:50 AM
sdeering
May 22, 2007 12:55 AM
