Engine stutters and there is an eggy smell
Old Nov 11, 2013 | 08:18 PM
weenlette's Avatar
Exclamation Engine stutters and there is an eggy smell
I have a 2001 Volvo XC70 whose engine has just started to stutter intermittently. you can feel the whole car shudder lightly when this happens. the shudder/stutter is accompanied by an eggy smell. anyone?
Old Nov 12, 2013 | 07:03 PM
difflock54's Avatar
The eggy smell will be your catalytic convertor.
May be clogging up or you may need new o2 sensors.
Get your fault codes read. That should give an indication of possible problem.
Old Oct 23, 2014 | 03:20 PM
SLOjohn's Avatar
Default Electronic Throttle Body Needs Cleaning
It's likely that you electronic throttle body needs cleaning. Because Volvo uses a crankcase ventilation system that pulls vapors from the crankcase back through the intake, the throttle body get gummed up with residue. The radiator fan housing must be removed along with some other parts and then the ETB must be removed. There a good videos on YouTube. Clean out the little air box attached to the crankcase. The car will run 100% better with a clean throttle body. The engine is running rich and the bad fuel/air mixture is causing build up in the catalytic converter. The converter can be damaged because it overheats when the fuel/air mixture is too rich. You should also check the Oxygen Sensor because that can also affect the fuel/air mixture.
das8track
Feb 5, 2013 04:51 PM
wellthatsnogood
Sep 21, 2011 04:06 PM
pinopinopino
May 30, 2011 05:29 AM
shlugendah
Oct 14, 2009 04:41 AM
fredimac
Nov 21, 2008 09:09 PM
