Lengths of Transmission to Engine Bolts
Old Oct 8, 2018 | 07:56 PM
godfearer960's Avatar
Default Lengths of Transmission to Engine Bolts
I have a 2005 Volvo XC70 with AW50/51 AWD transmission. I am replacing the transmission. There are many bolts used to mount the transmission to the engine. They were all removed with 13mm socket. There appear to be 3 or 4 different lengths of these bolts. I need to know which bolt length goes to which bolt hole. Since I have the parts catalog with my VIDA software, I thought I could find a detailed exploded view which would easily answer my question. However, after spending a couple of hours reviewing it, I still have not located any description of any of the bolts except the bolts used for the bracket for the rear engine mount (which is a total of 3 bolts), and a couple of the bolts attaching the starter. Obviously, in hindsight, I should have marked the bolts with a number or map or something, since now I am not exactly sure which bolts to use.
The repair description in VIDA section 43: transmission installation, certainly describes the bolt diameter, but not the lengths.
Most of the bolts are 40 mm long, some are 70 mm long. One is in-between, I haven't had a chance to measure yet, is, my guess, about 45 to 50 mm long.
good1662
Dec 26, 2014 12:05 AM
Dphase
Mar 6, 2011 02:21 PM
Sofar.
Apr 13, 2010 05:20 PM
Janus3
Aug 5, 2009 07:03 PM
westcoast gt
Jul 31, 2005 10:56 AM
