oil pressure drop
Old Dec 15, 2020 | 10:31 AM
clarkstar's Avatar
Question oil pressure drop
New member. Picked up 05 XC70 for cheap. 235,000mi. Compression test revealed low compression on #3. Planed head, replaced all valves, replaced PCV box while I was there. Now, motor runs great. Quiet and plenty of power. Turbo working properly. HERE IS ISSUE: Drive it for 10 minutes and we get a "stop safely low oil pressure" message. Sooooo. Flushed motor, dropped and cleaned pan and pickup tube. Replaced oil pump and pressure sensor. Filled with Castrol 10-30 Full synthetic and filter. Same result after 10 minutes of driving. Put a manual gauge on which confirms oil pressure drop.I'm at my wits end. Any thoughts on this?
Old Dec 15, 2020 | 11:58 AM
Originally Posted by clarkstar
dropped and cleaned pan and pickup tube. Replaced oil pump and pressure sensor. Same result after 10 minutes of driving. Any thoughts on this?
Yes - replace the pickup tube with the new style tube - made that mistake once, I put it back together, low pressure (with your symptoms) persisted, replaced tube - problem solved. Make sure the oil pan orings stay/stayed in place.
Old Dec 15, 2020 | 12:06 PM
clarkstar's Avatar
Thanks Hoonk. At the time, I sort of thought I should have used a new pickup unit. Will let you know if that works.
brettboze
Mar 26, 2012 06:25 PM
V-Jet
Jul 17, 2011 09:19 AM
neonracer193
Feb 18, 2009 09:37 AM
jfarsetta
Mar 4, 2008 08:15 PM
Nuria
Apr 14, 2005 10:44 AM
