Replacing rear upper control arm
Old Jul 5, 2014 | 11:46 PM
Greg150's Avatar
Default Replacing rear upper control arm
I found a replacement upper control arm for the rear of a 2002 V70XC at the junkyard on a 2001 model. A new arm is about $230 without bushings. I got everything off except where it attaches on both sides at the end toward the center of the car. I got the bolt out of each end. Is there a tool to get the bushings out of the mounting bracket so the control arm can come out?
A picture of the arm is here: OES Genuine W0133-1898049 Control Arm | Auto Parts Warehouse
As you can see, the one end has protrusions out both sides which go into bushings in a close fitting piece on both ends, so the arm is essentially trapped until the bushings are removed, or am I missing something?
Thanks
daver
May 27, 2013 11:21 PM
wilson32
Jan 8, 2012 08:13 AM
dave_vic_ozz
Sep 3, 2011 05:56 AM
quidam
Jun 6, 2011 08:27 PM
smoki
Dec 31, 2008 04:03 PM
