stalling when placed in gear after spark plug change
Old Sep 26, 2022 | 11:40 AM
vovor's Avatar
Default stalling when placed in gear after spark plug change
Hello comrades, 2006 xc70, changed spark plugs after mechanic stated code was caused by a misfire/ car was running rough.
code remained after plug change. and car started, ran great .drove about 4 miles, car stalled, starts fine, stalls now if placed in any gear,
reving in park would keep it running. Used NGK plugs.
. ANy thoughts ???
Old Sep 27, 2022 | 04:45 PM
misfire codes are pretty generic - can be caused by weak spark, incorrect fuel trim or on a rare occasion, something internal to the engine. Regarding changing the plugs, brand is less important than plug type and correct gap. More likely you have a fuel trim issue - ie intake air leak or exhaust leak causing the car to run lean or perhaps a fuel pressure issue (sensor/pump etc). Throwing plugs at a misfire was kind of like a hail mary pass - but now you need a better trouble shooting plan.
Old Oct 2, 2022 | 07:38 AM
madeesawnv's Avatar
this exact thing was happening to my xc70. my car was also running rough ie. hunting at idle, stalling at stops. i replaced the MAF, cool air intake, AND the very pricey throttle body , before finally doing trans fluid drain and fill..there were some sizable chunks of my transmission in the drained fluid, but after refilling, i was able to shift out of park, into drive, and actually drive?!
might be worth doing a transmission drain and fill before any very costly repairs
Old Oct 2, 2022 | 09:36 AM
Originally Posted by vovor
changed spark plugs
, car stalled,
. ANy thoughts ???
Yes when you replaced the spark plugs you took the turbo pipe over the engine off - when you put it back you introduced an air leak - check your plastic pipe installation.
vovor
2001-2013 model year XC70
Sep 26, 2022 11:45 AM
Angel Velasco
Jan 13, 2020 08:00 AM
Sand2011C70
Apr 17, 2016 04:10 PM
J Brad
Feb 6, 2012 10:11 PM
djwhizkid
May 7, 2010 06:32 AM
