Upgrades, am i ill ?
Old Jan 4, 2013 | 06:51 PM
Mr.Cummins's Avatar
Default Upgrades, am i ill ?
I just copied this from the introduction section, as i beleive it will get a few more hits here:
Hi guys, i'm new here....
New to the Volvo scene so to speak, i am looking to buy a XC70, 2001 model year with a 2.4 Turbo engine...
How can i identify this engine and what all can be done with it..
I'm thinking it's packing a lot more punch, considering that the BMW M50B25 (2.5 liter NA) is pushing only a 4hp fewer than this 2.4 Turbo application....
I know how to work with BOSCH and Siemens ECUs, what ECU does this Volvo use ?
I've worked with BOSCH ME1.7 to 7.2 and Siemens MS42,MS43 and MS47 units...
So pretty much what i'm asking is...
How high EGTs can i see before i will be having trouble with pistons/rings/valves ?
How much boost will the motor hold up to with the stock injectors, stock turbo ?
Is there any turbo upgrade easily available that will drop drive-pressure so that i could run more boost without sacrificing head-gasket damage ?
I'm still looking at buying this Volvo i've been offered at a very good price, reasons being that some o-rings/gaskets in the oil pan failed causing catastrophic damage to the engine, car has 135.776km on it where it stands now at a friends garage and a replacement engine has been found with only 66.443km on it (i took a look at the instrument cluster and the parts dealer plugged up a reader to show me that all "computers" are in sync)
I will have the extra 2.4 engine for parts, should anything fail in the new engine, the catastrophic failure i described consists of main bearings and rod bearings being shut... the crankshaft is worn down and two rods are now oval shaped...
Top end of motor seems okay and the turbo on the older motor is NEW, so i will probably move that over to the replacement motor...
How much power can these transmissions take?
Am i correct to assume that the T5R has the same engine, just a different tune and probably another turbo ?
All answers are greatly appreciated
Old Jan 5, 2013 | 07:23 AM
Mr.Cummins's Avatar
Really, nobody ?
Old Jan 5, 2013 | 08:41 AM
Not yet. People are not just sitting waiting to respond to such an objective topic.
Anyway, in my opinion I think the entire old motor system is trash, especially the top end and turbo. Starve a turbo oil for just a little while and it will wear real quick. Also the o-ring failure usually messes up lifters, valve stem seals and may even cause the head journals to wear pretty quick.
As for HP tolerances, you may to check with a few other sites like www.SwedeSpeed.com or a few other Volvo forums that are slanted towards performance upgrades. Things on the 70 series changed some in '01. The 850's seem to handle up to about 320 HP fine, above that and the tranny and other drive train parts start to suffer. If you go to www.iPdUSA.Com and look at their performance upgrades for the car like stage 2 or 3 will likely tell you the stock limits.
traildog
Jan 17, 2013 08:05 AM
laser99
Nov 16, 2011 09:47 PM
05VolvoS40
Nov 4, 2005 02:28 AM
swede850T
Oct 13, 2005 02:34 AM
brushfires60
Jun 14, 2005 10:53 PM
