85 Turbo climate control problem - Help!
Old Aug 12, 2008 | 07:00 PM
joshuare's Avatar
Default 85 Turbo climate control problem - Help!
I have a 1985 Turbo wagon, and the heater is always on. The fan works fine, but there is no way to adjust between hot and cold. Anyone know how to manually switch the vent so that it only blows cold instead of hot?
Old Aug 12, 2008 | 07:02 PM
Default RE: 85 Turbo climate control problem - Help!
Which model is it? Also it should have a heater control valve that is controlled by vacuum under the hood.
Old Aug 12, 2008 | 07:17 PM
joshuare's Avatar
thanks for the reply. I'm not sure what model the car is, it only says in the manual that it is a 1984 turbo wagon. it has the same manual as the DL, GL and GLE, if that helps.
Old Aug 12, 2008 | 08:16 PM
It has to be either a 240 or 740. There should be the heater control valve under the hood by the firewall with the heater hoses attached to it. Try moving that arm and see if the temp changes.
Old Aug 12, 2008 | 08:52 PM
joshuare's Avatar
well, i examined pretty thoroughly under the hood and was unable to find anything that looked like a heater control valve. It is easy enough to see where the heater hoses go through the firewall, so I wonder if the valve is behind the firewall. I had a friend move the heater control back and forth in the can and I was unable to see anything moving under the hood. any thoughts?
Old Aug 12, 2008 | 09:42 PM
Not right off hand let me see what I can dig up tomorrow.
Old Aug 12, 2008 | 10:52 PM
joshuare's Avatar
alright, i'll check back. thanks for the help!
Old Aug 13, 2008 | 06:15 PM
If it is a 740 then the heater valve will be outside. If it is a 240 then it will be inside the car. But I really need to know if it is a 740 or a 240.
Old Aug 13, 2008 | 08:08 PM
joshuare's Avatar
It is in fact a 240 - I found out for sure.
Old Aug 13, 2008 | 09:11 PM
Then the heater valve will be inside the car. When the car is warmed up is both heater hoses hot?
Old Aug 13, 2008 | 09:35 PM
joshuare's Avatar
yeah, it seems as though both heater hoses get hot.
Old Aug 15, 2008 | 06:01 PM
Then it would sound like the valve is bad.
Old Aug 15, 2008 | 06:44 PM
joshuare's Avatar
yeah, that makes sense to me. do you think i would have to disassemble the dash to get to the valve?
Old Aug 15, 2008 | 07:18 PM
Remove the panel to the right of the gas pedal and look for the valve. I have never had to replace one so not really sure.For now try pinching both hoses off and see if cold air comes out.
bluemotev
Feb 23, 2014 10:09 PM
yankengr
Sep 19, 2010 02:32 PM
cheesecake
Aug 8, 2009 07:11 AM
jfikentscher
May 31, 2006 09:58 PM
