2001 S80 Passanger Side Climate Control Problem, NO passanger side A/C??????
Old Aug 6, 2006 | 12:13 AM
alexr2130's Avatar
Default 2001 S80 Passanger Side Climate Control Problem, NO passanger side A/C??????
2001 Volvo S80 2.9L base model.
When I turn the A/C on, whether on AUTO or MANUAL, only the driver's side blows cold air and the passanger side just blows regular air that is not cooled. The dual feature still works though, which allows for me to set one side to blow hot air while the other side blows cooler air. The compressor works fine and there is plenty of gas inside.
ANY SUGGESTIONS?
Old Aug 7, 2006 | 02:25 AM
v62cobra's Avatar
Default RE: 2001 S80 Passanger Side Climate Control Problem, NO passanger side A/C??????
Had this problem on the benz, replaced the dual climate module and the problem was fixed. It can also be a bad plenum.
Old Aug 8, 2006 | 01:20 AM
Could also be Low on Freon.
The system does wacky stuff when low on freon.
Old May 13, 2009 | 10:33 AM
snkpkp's Avatar
i just replaced the A/C Compressor as the bearing was making a sound, and after changing it the AC now blows COLD air only in one side and regular air on the other, GAS charge is full, any suggestions?
EChem
Oct 4, 2017 02:57 AM
slipperysalmon
May 1, 2014 03:10 AM
Wza
Oct 22, 2013 12:26 PM
Bert07
Oct 22, 2011 03:05 AM
hubmachine
Aug 29, 2006 08:41 PM
