93 940 intermitten stalling
Old Nov 15, 2003 | 02:20 PM
josep's Avatar
Default 93 940 intermitten stalling
HI I purchased a 1993 940 non turbo. I've had it for a few months. once in a while while driving when its below 55 degrees outside the car just dies for no apparent reason. so far its happened at normal street speeds 35 - 45 mph. I changed the plugs, wires, rotor and distributor cap when I got it.</P>
has anyone had this problem &amp; what was the fix? thanks very much.</P>
</P>
</P>
Old Nov 16, 2003 | 08:27 PM
Erock198's Avatar
How is the fuel economy? Does it seem to use a lot? Does it start fine everytime but stall out? Does it stall out when the car is cold or warm?
Old Nov 17, 2003 | 12:19 PM
josep's Avatar
HI the fuel economy seems to be about where it should be, the car starts up fine every morning, The stall seems to ocur just asthe car gets warmed up. I let it warm up for about a minute before I drive and then it happens after driving about 7 miles or so. the car will start right up after it stall and runs with no problem.</P>
</P>
Old Jan 16, 2004 | 08:14 PM
delta21's Avatar
have you checked the fuel pump?I had a jeep cherokee that did that
Old Jan 22, 2004 | 01:55 AM
sbeemish's Avatar
Check the main wiring harness for shorts. Had a similar, not exact,problem. I would be driving, make a turn and the car would die. Minutes later the car would start up without a problem. If the miles are beginning to get up there the harness begins to deteriorate. Just a thought......Others may have differing views....
Old Jan 22, 2004 | 02:05 PM
josep's Avatar
<IMG src=smileys/smiley17.gif border="0"> HEY GANG, thanks for the advice and imput. I finally got the problem sorted out. turns out the throttle plate was pretty gummed up. What would happen is that the plate would get stuck and restrict airflow and cause the stall.
volvoinct
Jun 8, 2022 03:30 PM
GaryBrad
Nov 13, 2005 08:30 PM
gtf8326
Jul 1, 2005 10:45 PM
gtf8326
Jul 1, 2005 09:49 PM
940 fan
Sep 5, 2004 10:19 AM
