95-850 Turbo eng quits running after it warms up
Hi - I have a 95 - 850 Turbo that runs very well when cold and in the warming up process but it stalls out or quits running after it warms up and will not restart until eng has cooled back down some what. Then the longer I let the eng cool the longer it will run until quitting, so it is temperature sensative or related. On a suggestion form a friend I replaced the coolant temp/sensor but still same problem, I hope the new sensor was not bad from stock but I could check by heating it up and watching it's resitance ith a meter. Now during one of my down times I popped the hood to check things out and noticed the radiator fan was not working - ok but if it doesn't work then whyhas not my temperature gauge on the dash never has indicated warmer than ususal - not unless the eng temp shut off sensor is supper sensative and does shut it down at the slightest increase.
Another thing that I noticed on the instrument cluster was the turbo indicator is still - dose not move - pointing straight up no matter how fast I am going.
When at home I thought to check the rad/fan and so I jumpered it to battery but found that it works fine. Then I thought to check the fan relay and when I disconnected the tepm/switch there on the thermostat housing the fan came on so that would tell me the relay and fan is good, Correct?
I just checked my codes and they agree with what I got the other day - they are - 213,214,141,142
My question is what do I do next to eliminate and or acctually trouble shoot my problem? Any suggestions? Let me assure you that any info given will be appreciated and taken seriously! Thank you all very much!
SR Heer
