Rough idle after engine warms up
Old Mar 9, 2010 | 04:15 PM
brasstacks's Avatar
Default Rough idle after engine warms up
I have a 1999 volvo v70 GLT turbo
The problem I an experiencing is a very rough idle. It bounces the rev counter needle 3-4 notches every 2-3 secs. This only starts when the car warms up.
I took the car to my mechanic who ran a diagnostics and could not get a problem code. He said to wait until the engine light came on and that it would do no damage to the engine. It has been 5 months and it is getting worst.
Has anyone experienced this problem or have a solution.
All ides would be much appreciated
Thanks
phill
Old Mar 10, 2010 | 07:11 AM
My guess would be a vacuum leak somewhere. Check around the idle valve first. It could also be a bad idle valve.
Old Mar 10, 2010 | 07:22 PM
spaded09's Avatar
I had same problem so replaces idle valve and problem went away.
Old Mar 11, 2010 | 09:12 AM
brasstacks's Avatar
thanks guys for the reply.
Both of you point out the idle valve. I am guessing in both your cases there was no alert to the problem fron the onboard computer.
The question is now - where is the idle valve? I don't have a shop manual to look it up. Is this something I could switch out myself?
Again thanks for thee info
phill
Old Apr 16, 2010 | 07:57 AM
modelageek's Avatar
Default I might need a new Turbo.please help
Hello. ... I am new here..... I am looking onto purchasing a 2000 s70 awd. The car smokes at idle.... the seller wa informed by his mechanic that it is proabably the turbo....... I called volvo for an estimate on just the part. it was aboout $1200.......I would like any feedback on this issue you have......Are they hard to replace.......is there another company making replacment turbo. etc etc......thx in advance
rook
Jan 11, 2009 01:26 AM
MDJ240
Mar 28, 2008 12:01 PM
SR Heer
Nov 1, 2007 06:11 PM
SR Heer
Nov 1, 2007 10:53 AM
MDJ240
Feb 28, 2007 09:22 PM
