Upgrade with power steeting
its a 1973 so you'd have to research what steering racks could be swapped in. Once you figure that out,then you'd get the choice of seeing if there's a similar engine model that can support the PS pump or consider going with an electric PS pump design. With that said, its a pretty small car that doesn't really need power steering - if you find the steering too heavy, it may be due to tires. alignment or worn components (including the steering box).
Doesn't the 1800 have a recirculating ball steering box? (not a rack and pinion)? Not sure if ANY Volvos with that steering box design were ever powered.
