Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Amp Installation: Negative and Positive Speaker Wire Colours
Old Apr 16, 2008 | 03:14 PM
lowbeer's Avatar
Default Amp Installation: Negative and Positive Speaker Wire Colours
Hi,
I have a 1997 Volvo 850 Wagon. I am going to install an amp and sub in the car using the speaker connections in the rear pillar. I think they are tweeters. Does anyone know what colour the negative and the positive wires are?
Secondly, can anyone recommend a good remote power source for the amp and where it is located? (i.e., a wire that is only live while the radio is running.)
Thanks,
Nate
Old Apr 16, 2008 | 07:51 PM
Default RE: Amp Installation: Negative and Positive Speaker Wire Colours
Hope this will help
Old Apr 17, 2008 | 01:10 PM
lowbeer's Avatar
Thanks for the info. Would it be possible to get the pdfs of that file?
How do I find out if my car has an amp? Where is it located in the car (I have a 97 850 Wagon)?
Thanks again.
Nate
Old Apr 17, 2008 | 06:54 PM
I can't e-mail the file it is way to large.
I can only do it the way I did it.
If your car had an amp it is behind the radio burried in the dash.
If you had an amp it would be plugged into the Amp port on the back of the OEM radio.
Old Apr 18, 2008 | 02:14 AM
ron1's Avatar
Default RE: Amp Installation: Negative and Positive Speaker Wire Colors
you can pull out radio fuse twist wire and plug into one side of the fuse hole then plug fuse into same spot ,make lead short so it doesn't touch other metal
antman85
Jun 9, 2013 04:10 PM
Rickford
Feb 17, 2013 04:41 PM
Paudman
Apr 3, 2008 07:09 PM
MagicM1364
Dec 22, 2007 12:02 AM
ko_kidd
Aug 25, 2006 08:53 PM
