Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Cleaning up the wiring on my old project 240, adding grounds, replacing fuse panel
Old 01-31-2018, 09:40 AM
joedirt's Avatar
Default Cleaning up the wiring on my old project 240, adding grounds, replacing fuse panel
I took on a 85 240 with a 302 swap that now runs. I'm in the process of trying to figure out what stock Volvo wires I can eliminate which might take me a while. Ive also added some things in the engine bay such as independent relay for the fuel pump and wiring for a electric fan controller. I might run a small amp down the road for the stereo as well as aftermarket gauges which will need power as well.
I was looking into distribution blocks and was a bit hesitant about bolting a 12 volt power source with studs sticking out to the firewall for instance. I guess im asking are they safe lol?
Second question was about adding grounds, i'm not 100% this motor is properly grounded as it was a swap done years ago and visually it looks okay but how much does some thick wire cost. Can I simply just add a think enough gauge wire from the block to the chassis or battery or both? Would it hurt to go overkill on the grounds?
Lastly is there any guides to retrofitting a more up to date fuse block and replacing the old ceramic fuses with something more modern? I realize that is a risky huge task if not labeled correctly.
Old 02-25-2018, 05:47 PM
tony1963's Avatar
I'm impressed that you took on such a job!
You can buy generic fuse panels that have a variety of fuse capacity connections and also generic connectors. The car is over 30 years old so the wiring is that old too.
jmana
10-14-2020 05:17 PM
rpmakrues
10-13-2019 11:12 PM
donf
07-05-2013 02:52 PM
123c70
08-27-2012 03:48 PM
volvoQ's
11-27-2010 04:31 PM
Quick Reply: Cleaning up the wiring on my old project 240, adding grounds, replacing fuse panel
