Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Electrical problem. your insight?
Old Oct 16, 2007 | 08:19 AM
Patdon10's Avatar
Default Electrical problem. your insight?
Problem #1: Cigarette lighter only works when the headlights are off. Its not the instrument cluster circuit board, because I just changed that. Any other ideas?
Problem#2 (main problem): Today when I was trying to install my volt meter light, I eventually gave up for today deciding I didn't have to proper connections and decided it was best to wait until I get them to continue. I had 2 hot wires - a +12 and a ground. I taped up the +12 with electrical tape so it wouldn't touch anything and fry my electronics. I decided the ground wouldn't do any damage, so I left it untaped. This couldn't do anything, right? Wrong. Immiediatley, it touched something inside the dash and my radio and volt meter cut out. I checked the volt meter by wiring it directly to my battery, it still works. I looked inside my radio to see if the fuse was still good - looked good. I checked my fuse box to see if all the fuses are still good - looked good. My volt meter is getting its power from the brown power wire inside the center console. The radio is getting power...from the red radio wire? Are these the same power wire? Did I burn out the fuse? Where is the fuse? Anyone have any ideas? I'm stumped on this one...
Old Nov 6, 2007 | 04:22 PM
cbevis's Avatar
Default RE: Electrical problem. your insight?
how old is you car?
mrscullini
Feb 13, 2013 09:11 AM
zerochills
Aug 31, 2009 12:48 PM
3Muskeeters
Jul 21, 2009 03:53 PM
Patdon10
Oct 17, 2007 10:20 PM
Jacob Dylan
Jun 15, 2007 07:45 PM
