Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
factory radio took a crap
Old May 21, 2007 | 03:40 PM
volksnut's Avatar
Default factory radio took a crap
I disconnected the battery to do some work under the hood only to find out after my radio won't work....well the screen says EEEEE , you can tell at full volume it's on but can't change stations or anything....do you have to reprogram it after disconnecting battery or what?
Old May 21, 2007 | 10:30 PM
S70driver's Avatar
Default RE: factory radio took a crap
There is a radio code that you have to put in to be able to use the radio again. Cal your local Volvo dealership and give them your VIN# and they will give you your radio code.
Old May 22, 2007 | 08:11 AM
mcguij1's Avatar
yea you need to get a code from your local dealer for your car...its a safety issue which helps in case your stereo was ever stolen...just dont screw up your code to put in your you'll have to run your battery down for 2 hours just to restart the error code...the stereo locks after 3 or 4 tries...
Old Jun 8, 2007 | 03:45 PM
volksnut's Avatar
okay I got the code, how do you enter it in
Old Jun 8, 2007 | 05:01 PM
volksnut's Avatar
okay, I found out how to enter it in, but the radio already says EEEE...can I just disconnect the battery or do I need to leave the radio on for 2 hours continueous to enter the code
rvinson2
Apr 27, 2009 07:28 PM
vfrman
Jan 6, 2009 07:56 PM
Psaboic
Nov 4, 2008 07:44 PM
S70driver
Aug 11, 2008 07:33 PM
andym
Dec 6, 2007 06:17 PM
