Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Installing a double-DIN radio in an 850
Old Jan 20, 2009 | 04:07 PM
DOHCRT's Avatar
Default Installing a double-DIN radio in an 850
I'm thinking about replacing the stock radio in my 96 850 with an aftermarket double-DIN size DVD head unit. I cannot find any installation kits for double-DIN radios, and I doubt that an aftermarket unit will fit nicely without some sort of adapter. Any ideas?
I worked on an S70 at work not too long ago that had a double-DIN aftermarket radio installed. It didn't have an adapter, and sat loosely in the DIN. This is what I want to avoid.
Old Jan 25, 2009 | 02:00 PM
cbevis's Avatar
Default RE: Installing a double-DIN radio in an 850
isn't the standard radio cubby size of an 850 already double DIN? There may be a metal box sleeve the OEM deck slides into that you'll have to retain in order for the aftermarket DVD to fit. Unless it's a Pioneer or something....those come with a sleeve.
You could hit up the install bay at your local Best Buy and find out what they'd use to install double DIN in an 850. Probably your best bet.
slowmod
Jul 10, 2022 11:04 PM
Royalty
Aug 23, 2009 10:58 PM
wmallick
Jan 27, 2009 01:46 PM
ddub
Aug 31, 2008 07:07 PM
Aaronius
Apr 10, 2008 06:48 AM
