Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Radio??
Old Nov 21, 2005 | 03:15 PM
dmsee's Avatar
Default Radio??
i just bought 93 850 and its got stock radio i turned it on but i cant find any radio station??
i checked the antenna its plugged in what else is there to check???
Old Nov 21, 2005 | 09:37 PM
Default RE: Radio??
Did you make sure it is plugged in in the trunk?
Old Nov 22, 2005 | 12:06 AM
dmsee's Avatar
Default RE: Radio??
yes
Old Nov 22, 2005 | 12:29 AM
Default RE: Radio??
Maybe there is a problem with either the antenna wire or the antenna itself. Does the mast work normally?
Old Nov 22, 2005 | 01:04 PM
dmsee's Avatar
Default RE: Radio??
mast??
Old Nov 22, 2005 | 05:41 PM
ZIGZAG's Avatar
Default RE: Radio??
The mast is what he is refering to as the (Whip) or metal part that sticks out of you car. there is a connection at the bottom of the mast (inside trunk maybe)
Old Nov 22, 2005 | 08:30 PM
dmsee's Avatar
Default RE: Radio??
yes everythinhg plugged in
Old Dec 6, 2005 | 05:32 PM
lanciak69's Avatar
Default RE: Radio??
ive had a problem like this before it was a brake in the coaxal cable at the rear of the radio best way to test this is get a cheep arial [i keep one just for this ] plug it in and try your radio if it works try it at the rear the trunk or boot if it does not work its the cable
cbgav
Sep 10, 2007 05:25 PM
