Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
DiCE funcion
Old Apr 30, 2017 | 11:50 AM
burgessian's Avatar
Default DiCE funcion
The DiCE seemed to work when powered by DC power supply. However,
now I've had chance to try the DiCE connected to the OBDII port and the ‘Vehicle Interface Status' LED is out. No through put data.
So did continuity test of the cable:
orientation of pins looking down in to the OBDII connector, then pin 1 top left.
1...N/A
2...Red
3...Blue
4...Bk
5...Bk
6...Yellow
7...Orange
8...N/A
9...N/A
10..N/A
11..Purple
12..N/A
13..N/A
14..Green
15..White
16..Brown
Problem: the ordering of the wires in header connector onto the DiCE:
Bk, Bn; Rd; Or; Gn; Yel; Bl; Pur; Wh;
However, different order in this photo:
Or; Bn, Bl; Gn; Yel; Pur; Rd; Wh; Bk.
Both mine and that board the same green PCB board.
http://www.autotool.fr/upload/pro/vi...rd-display.jpg
Can anyone verify from a fully functioning DiCE please.
Burgess
Old May 9, 2017 | 08:20 PM
burgessian's Avatar
Reason for asking: there is no through put of data from the vehicle. The led single flash then goes out.
The DiCE tests OK from the computer. And the OBDII port works fine. So I suspect the order of the 9-wires in the header maybe wrong.
Old May 10, 2017 | 10:23 AM
pierremcalpine's Avatar
Where are you located?
Old May 14, 2017 | 07:20 AM
burgessian's Avatar
Thanks for responding.
I'm in Wales UK.
The DiCE self checks with on faults
When connected to the OBDII port on the car no communication.
I've done a continuity check on the cable and not brakes.
Hence my first post, if I knew the order of wires from the 9 pin header on the DiCE board to their positions in the OBDII connector, I could check if they match.
Old May 15, 2017 | 05:59 AM
Ah, ok a bit far to send you mine to compare. I have lent my unit out but would be happy to do some continuity tests sad soon as I get it back. I will post back when I have it in hand.
Old May 15, 2017 | 03:34 PM
burgessian's Avatar
Thanks again, I'm surprised there's been no response on two local UK forums.
georgedsmith
Jul 10, 2021 04:31 AM
Ryan Baker
Feb 16, 2017 06:28 AM
autonumen
Dec 25, 2011 08:11 PM
supmotelec
Oct 11, 2011 04:55 AM
JackBlair
Mar 3, 2011 05:56 AM
