Detailing Discuss detailing your ride inside and out here.
Best All-In-One Product: Pinnacle XMT 360 Corrects, Cleans, Seals
Old May 6, 2014 | 06:05 PM
PinnacleWax's Avatar
Former Sponsor
Default Best All-In-One Product: Pinnacle XMT 360 Corrects, Cleans, Seals
Pinnacle XMT 360™ Corrects, Cleans, Seals
Mirror-like gloss after just one step!
XMT 360™ by Pinnacle is a revolutionary new product that combines correction, cleaning, and sealing into one simple step. This all-in-one wonder eliminates the need to use a separate mild swirl remover, paint cleanser, and sealant, yet you achieve the same depth, gloss, and slickness! XMT 360™ is total car care made easier.
XMT 360™ is a breakthrough in quality car care. I say “quality” because there are many cleaner wax type products on the market that just do not perform. But XMT 360™ does everything you’d expect from a one step product and a lot more.
Corrects. XMT 360™ does what no mere cleaner wax can do; it removes light swirls and imperfections to leave the paint looking flawless. Ultra fine abrasives - so fine they are not perceptible by sight or touch - gently blend away fine blemishes and visibly smooth the paint. Light spider webbing and water spots vanish. XMT 360™ works like a mild swirl remover but, remarkably, it eliminates the need for a separate cleansing lotion or sealant.
Cleans. XMT 360™ contains cleaning agents to remove oxidation and uncover the glossy, vibrant paint underneath. Any type of paint instantly appears deeper, glossier, with more vivid color. XMT 360™ removes dull films and wax build-up to bring new life to the paint.
Seals. Besides correcting and cleaning the paint, XMT 360™ deposits a glossy, slick layer of durable polymer protection. This is not a one step product that has to be followed up with another sealant for real protection. XMT 360™ is a premium paint sealant that will provide months of paint protection against salt, water, industrial pollution, UV rays, insects, and road grime. XMT 360™ is so effective as a sealant, you’d have a tough time distinguishing its mirror-like finish from other premium non-cleaning paint sealants.
XMT 360™ is an absolute time-saver. Go from washing to drying to XMT 360™ and you’re done. This user-friendly product does not require buffing. Polish XMT 360™ until it disappears. It leaves no stubborn haze. Even when applied in the sun, XMT 360™ is a breeze to apply and remove.
XMT 360™ is designed for application with a buffer. Its thick consistency prevents it from being absorbed into foam pads too quickly (This effect is even more impressive when used with CCS Foam Pads by Lake Country, made to keep more product on the pad’s surface). Excellent lubrication provides adequate working time to allow the cleaners and abrasives to do their job. Once the abrasives have broken down, XMT 360™ literally disappears as you polish. Not only does XMT 360™ combine three detailing steps, it eliminates buffing to save you even more time!
XMT 360™ is a professional detailer’s dream. On vehicles that are in good condition, XMT 360™ is all you need to completely transform a customer’s vehicle in the time it would normally take just to apply the wax.
XMT 360™ performs like three products in the time it takes to apply one product. It requires no buffing. It looks flawless on any color paint. And, it has an addictive cherry scent. XMT 360™ could be the perfect all-in-one product.
You be the judge. Try XMT 360™ by Pinnacle on your own vehicle and see how much time and effort it saves you. Compare the results to what you get from your multi-step process. XMT 360™ by Pinnacle will become your go-to product for one-step paint correction, cleaning, and sealing.
Directions:
1. Prep the vehicle by washing and drying it. Use Pinnacle Bodywork Shampoo and then one of the Cobra Guzzler Waffle Weave Microfiber Drying Towels.
2. We recommend applying XMT 360™ with a Porter Cable 7424. For the best results, use the CCS Green Polishing/Finishing Foam Pad by Lake Country.
3. Apply a quarter size amount of XMT 360™ onto the pad.
4. With the polisher turned off, spread XMT 360™ over a 2 x 2 sq. ft. section to avoid splatter.
5. Set the maximum speed at 5 on the Porter Cable 7424. Work XMT 360™ in a back and forth, overlapping motion.
6. Continue to polish even as the product dries. XMT 360™ disappears, leaving nothing on the paint but a clean, glossy shine. There is no need to buff.
PinnacleWax
Jul 16, 2015 12:15 PM
PinnacleWax
Feb 10, 2015 12:27 PM
PinnacleWax
Jul 9, 2014 12:19 PM
PinnacleWax
Jan 9, 2014 05:20 PM
antonio
Jun 6, 2011 06:42 PM
