92 940 won't shift out of third gear into overdrive
Old 06-27-2017, 09:08 AM
Cliff Whipple's Avatar
Default 92 940 won't shift out of third gear into overdrive
The third gear light on dashboard won't go out. Won't shift into overdrive, is there a solenoid I need to replace?
Old 06-28-2017, 07:36 AM
tryingbe's Avatar
Old 07-02-2017, 04:23 PM
gerryg's Avatar
Hi there. Same problem with my 940 lpt celebration. Fitted bypass plate and now changing up to 4th but on the solenoid there was a cable approx 9 inches long extending to a sensor of some kind lower down on trans box. I cut this cable but I don't know what it is for. would appreciate any help you can offer. Did you have this as well? Thanks.
sadielee
11-24-2020 07:39 AM
elchingon2002
07-22-2014 06:09 PM
yyk
02-06-2013 01:00 AM
Vee
01-13-2009 06:05 PM
Quick Reply: 92 940 won't shift out of third gear into overdrive
