Forum Issues Discuss any issues you are having with the forums here.
srs light
Old Jun 18, 2019 | 12:30 PM
kezbo77's Avatar
Default srs light
I have a Volvo 850s automatic 1994 and I need to remove the srs light. Can anyone advise please.
Old Jun 18, 2019 | 05:06 PM
the light is telling you one of the airbags or sensors is not working. Check out Volvotips.com to see if the service manual shows how to use the diagnostics LED to read the fault codes for the SRS system. Or are you asking how to remove the bulb from the instrument cluster? To remove the cluster you need to undo about 7 screws holding the dash cover down (including one or two hiding in the vents) then pry up the cover on the driver's side. the cluster unclips then you need to undo the cables before lifting out the entire unit. Search online for vids or write ups on repairing the odometer to see how to access the cluster. Same thing as replacing burn out back light and warning bulbs which pop into the back.
Old Jun 19, 2019 | 04:22 PM
kezbo77's Avatar
Yes I wish to remove the bulb. I will give it a go thank you for your help
Burn Stains
Oct 6, 2011 08:22 AM
BGoins12
Apr 28, 2011 06:49 AM
rspi
Nov 10, 2010 10:19 AM
