Is there a way to check light bulbs with a Analog Multimeter...
Old Jun 10, 2011 | 08:46 PM
Default Is there a way to check light bulbs with a Analog Multimeter...
I made it through about 44 years without using a multimeter. Now I have one and need to learn how to use it. So far I have only used it to check batteries and check a line from start to finish for a broken wire. I hope I catch on soon.
Can I check light bulbs with this? I'd like to check some of these bulbs to see if they are blown without tearing out a switch.
Old Jun 10, 2011 | 08:55 PM
eeeewidner's Avatar
Yes. Check for continuity. Does your meter have a buzzer integrated in it?
Old Jun 10, 2011 | 09:23 PM
This is the one I have.
http://www.walmart.com/ip/Voltage-Meter-10729W/14521542
Old Jun 10, 2011 | 09:56 PM
eeeewidner's Avatar
With that meter it seems that if you can add power to the bulbs to test them. I used to have one of those type of meters years ago and found that they are limiting on alot of things automotive related.
Old Jun 10, 2011 | 10:03 PM
I think I figured it out. When I turn the meter to the x1K and X10 yellow areas near the 11 o'clock position it gives me a reading on the new bulb. I'll check the rest of them with that.
Old Jun 10, 2011 | 10:41 PM
eeeewidner's Avatar
See if you can find a resistance specification for the bulbs. That setting will give you a accurate reading for ohms.
Old Jun 11, 2011 | 04:23 AM
Well, a bulb is either blown or not, correct?
Old Jun 11, 2011 | 08:45 PM
eeeewidner's Avatar
Lol. Very much true sir..
Old Jun 14, 2011 | 10:37 PM
clean850R's Avatar
If it pegs full or not move it's bad! Somewhere around the new ones measurement is good! Doest have to be exact but close! Use the X10 position! Make sure the wire/ circuit you are testing is unplugged at both ends! Just a tip! Good luck!!
Old Jun 28, 2011 | 05:30 PM
Typhoon's Avatar
Just measure resistance between terminal and side shell. Should be low. High resistance = blown.
niurik
Aug 26, 2013 10:56 AM
AnEskimo
Mar 2, 2012 05:35 PM
coolson
Jul 4, 2010 11:17 PM
Evo 850
Jan 2, 2008 08:50 AM
Clueless Scott
Jun 28, 2006 09:45 PM
