'02 XC70 timing belt water pump change
Old Sep 16, 2011 | 07:02 PM
ylwgto's Avatar
Default '02 XC70 timing belt water pump change
Hi all,
Below is a series of timing belt service questions I have before taking this project on. My car is a 2002 XC70 with 103K.
I was able to find great resources for the TB/WP DIY steps, but they all seem to be for the older engines with the hydraulic tensioner. Are there any write ups (with pics) on how to adjust the mechanical tensioner on my car during the cam line up and belt install?
Does the VVT play into the install and does having it on the car change any of the steps in the pictorial DIY's that are referenced in the forums?
Also, is there a source for torque specs on all the bolts involved? is loctite recommended for the tensioner and idler bolts? how about the water pump bolts?
finally, i plan on inspecting the water pump (and bought a pump to swap on), but my car only has 103K on the clock. if the pump looks good would you recommend leaving it alone for another 60K or will the new tension on the TB fail the pump quicker than that?
Thanks!!
Old Sep 22, 2011 | 12:55 PM
ibanez958's Avatar
-always recommend to replace t-belt tensioner & idler when replacing t-belt.
-is your water pump used?? if so may as well leave the pump alone
-you don't necessry need to lock the cvvt hub to replace a t-belt if you know the procedure, but if u mass up the timing while u are doing it, then u will require a special to lock the cam at the back & a special procdure to set the cvvt back to the correct timing.
-there is a special procdure of setting the tensioner. your's should be a spring tension. the setting is depend on the temperature your car is @.
Jeffers
Jan 1, 2014 01:25 PM
majorcode
Nov 4, 2013 06:41 PM
Maximus from the 915
Oct 7, 2011 03:31 PM
kingmf
Feb 17, 2010 10:07 PM
95volvo850
Sep 16, 2009 09:30 AM
