121 code won't clear! Can you help?
Old Apr 4, 2017 | 12:26 PM
mikeri1's Avatar
Default 121 code won't clear! Can you help?
I have a 1994 Volvo 850 turbo wagon. So I've been doing some pre-maintenance items. Here's what happened- I disconnected the air inlet hose to gain access to the dipstick to change the ATF. I then went for a little drivey to heat the fluid back up, and realized I did not clamp the hose back. So it came off and I barely made it back with the check engine light on. Pulled the code off OBD1 as a 121. I tried to reset it doing the hold down wait ten seconds twice with no luck in port 2 and 3. (I noticed the light did not came back on after the first hold down). It runs great but.... can you please help me kind Volvo masters!
Thanks!!
mcintorb
Apr 30, 2012 03:03 PM
wdshea
Oct 20, 2010 06:28 PM
grantbennett2
May 22, 2008 03:57 PM
groovypet22
Mar 26, 2008 02:42 PM
SirJester
Oct 18, 2007 06:09 PM
