Lambda (CEL) light code 121.
Old Oct 18, 2007 | 06:03 PM
SirJester's Avatar
Default Lambda (CEL) light code 121.
I have a 1995 850T5R Wagon that just came up with a Lambda light. Checked the codes and the only error I am getting is on the Fuel Management system plug is 121 which is, I believe, MAF.
What do y'all recommend here? Should I take the MAF off and clean it out or do I need to start scouring the local shops here in central Finland to find a new MAF? BTW there are no drivability issues and fuel is economy is where I expect it. Also light went off on dry day and now as it is wet and cold it came back.
TIA Alex
Old Oct 18, 2007 | 06:09 PM
Default RE: Lambda (CEL) light code 121.
I would check for vaccum leaks and clean the MAF and see what happens from there.
mcintorb
Apr 30, 2012 03:03 PM
wdshea
Oct 20, 2010 06:28 PM
grantbennett2
May 22, 2008 03:57 PM
Typhoon
Jan 13, 2008 08:34 AM
MikeySq
Nov 4, 2006 05:35 PM
