15% discount at Volvo Specialist Garage in Beverley, East Yorkshire
Old Mar 15, 2011 | 08:10 PM
MotoGo's Avatar
Default 15% discount at Volvo Specialist Garage in Beverley, East Yorkshire
Hello all,
I would like to introduce my garage based in Beverley, East Yorkshire which specialists in Volvos. Jonathan (the owner/technician) is a certified Volvo technician with over 13 years experience, most recently in a Volvo main dealership.
MotoGo is 65% cheaper than main dealer labour costs and we are also offering a 15% discount off all servicing and repairs for members of this forum. Also, MOT's are just £29.99.
Give us a call or drop in to see us, collection and delivery service available.
www.motogo.biz
info@motogo.biz
01482 881171
Old Mar 16, 2011 | 06:45 PM
fcpgroton's Avatar
Former Sponsor
Welcome to the forum. Let's hope they don't delete this because you are not a sponcer.
Old Mar 20, 2011 | 04:35 PM
ricky20's Avatar
Default 1995 volvo 850
i have a volvo 850 and ive been having alot of trouble with it. It drives fine but when im coming to a stop or just parked it begans to sputter and sometimes even stalls. It also idles rough and stalls sometimes. rpms rises up and down as if i was pushing the gas. ive changed the fuel pump, tps sensor, coil pack, maf sensor, spark plugs, and spark plug wires and no luck..any ideas of what it could be?
ps. let me just add that when i 1st got the car it was doing the same thing then thats when i changed the maf sensor. it ran perfectly after that then a year later the problem came back..could it be that the maf went bad again or is it something else..any advice would be greatly appreciated
Old Mar 20, 2011 | 08:09 PM
When you say a lot of trouble, what does that mean. We would love to help you but you need to be specific and not whine, but list the problems. You have only listed one here and we don't even know if the car is turbo, how many miles it has, and we all know that you did NOT replace any coil packs because 850's don't have them.
Other than that, your problem is likely related to the idle control valve. It may be as simple as having a vacuum line torn or clamp loose. There is a thread here that a guy just wrote about his car stalling, etc.
Old Mar 22, 2011 | 04:38 AM
Aftermidnight's Avatar
I would check your relays.
Here is some info from Dave Barton's site:
"Dave, thanks for posting this information on how relays can interfere with ignition. I had a gradually worsening stalling problem over the past year and a half. The mechanics could not trace it, since the stalling was never associated with a "check engine" light (good mechanics but not Volvo specialists). The symptoms usually were a failure to restart after a short stop, but it eventually worsened to stalling in traffic. I guess the engine heat would cause a bad solder joint to open up and block spark to the engine. I replaced the various relays you mentioned and I have not had any stalling since then. I wonder if a Volvo specialist would have diagnosed the problem earlier? In this case I took your suggestion to the mechanic, and he admitted it would not have occurred to him. Definitely bookmarking your site for future reference!" M.L.
__________________
Old Mar 22, 2011 | 08:25 AM
JimKW's Avatar
Could be the fuel filter or a vacuum leak.
Old Mar 22, 2011 | 10:03 AM
boxpin's Avatar
I second the Vacuum leak. I think if it was a fuel filter there would be issues all the time. A vacuum leak will really show its true colors at idle.
Old Jul 10, 2011 | 10:58 PM
jeffintampa's Avatar
Sounds familiar, my850na is stalling at lights after a ,say, 1/2 mile 45mph city situation, also sort of bucks and won't find OD at about 2k. A lot or rain here and maybe crappy gas? Car runs great under accel. or a load, starts fine,(coasting in N after stall) and cold. Plugs? Thanks.
Old Jul 11, 2011 | 04:28 PM
TonyS's Avatar
As others have said here, it's worth checking those vacuum lines. I was having what sounds like a similar problem and finally noticed a bad hose at the vacuum tree that's under the throttle cable cover. That and a bad MAF sensor were (I think) the root of my trouble.
MotoGo
Mar 15, 2011 08:12 PM
CountryEuropean
Jan 6, 2009 09:34 AM
CountryEuropean
Jan 5, 2009 11:47 AM
CountryEuropean
Jan 5, 2009 11:19 AM
