1981 245 running rough after sitting
Old Jun 16, 2021 | 05:19 PM
jmhurtado's Avatar
Default 1981 245 running rough after sitting
As the title says, my Volvo is running a bit rough but only after it sits for an extended period. When I drive it consistently it's great but when I start it after resting for a couple days it has a difficult time turning over right away. Once it does turn over it cycles between running fine and then feeling as if it is misfiring. For the first couple of miles it runs fine but will have a rough idle when stopped and then slowly normalize. Any ideas here? I suspect a loss in pressure but wouldn't know where to start to diagnose/fix this. For a little background the car has had a decent amount of work recently. New injectors, injector housings, replaced air flow regulator, warm up regulator, PCV system and fuel filter.
anotherbrickindastreet
Apr 11, 2016 04:08 PM
peterz
Oct 13, 2013 02:54 PM
SolidHit
Engine & Internal
Aug 23, 2011 07:31 AM
pdieni
Jul 26, 2011 08:14 AM
DecalService
Nov 19, 2008 08:05 PM
