1989 740 trouble light malfunction.
Old 09-04-2019 | 10:17 PM
Thomas Eric Allen Hathaway's Avatar
Default 1989 740 trouble light malfunction.
Hello, my name is Thom, I am having problems with my 1989 740. The check engine light came on, and I then tried to run diagnostic-starting with oil and other fluid reservoirs and then moved on to the On-board Diagnostic. The reader on these old Volvos can fail or so I'm told The OBD light sensor is showing a solid light with no flashing or sequence. I then used a method I have used in the past fearing that the diagnostic light was malfunctioning. I used a test light along with insulated wires with plugs to take over the circuit. The test light also showed a solid light as well. Does anyone have any ideas on what might be the problem.
Thoughtyouhadme
06-03-2018 12:02 AM
jags
01-06-2013 07:34 PM
everritte
08-11-2011 11:09 AM
annamojo
04-18-2010 11:52 AM
uncle
02-23-2008 12:17 AM
Quick Reply: 1989 740 trouble light malfunction.
