2000 V40 fuel filter sensor??
Old Apr 23, 2022 | 03:57 PM
Bradrhoads's Avatar
Default 2000 V40 fuel filter sensor??
I want to replace the fuel filter on my 2000 V40 with new. When I was investigating, I noticed a band that encircles the filter canister. The bands function seems to be to scure a sensor. I'm curious what the function of this sensor is. (Yes, my band/clamp is broken) Does anyone know what that sensor is? Pic attached.
Vehicle presently has original fuel filter. 84k miles. I'm experiencing some hard starting - I have to crank it for 3-5 seconds before it starts. It used to start immediately. I'm thinking the fuel filter may be the cause. New plugs and air cleaner. I suspect the injectors are ok as well. Any advice would be appreciated.
Thanks!
Brad
Old Apr 24, 2022 | 01:36 PM
That fuel/vacuum gauge is for carb engines. Max pressure on the gauge is only 10psi. Your fuel injection is about 50 psi. An Appropriate gauge connects to the tire valve like port on the fuel system.
Old Apr 24, 2022 | 06:22 PM
Bradrhoads's Avatar
Hey Hoonk. Thanks! I see the Schrader valve I need to connect to. (Pic attached) Do you think this Harbor Freight gauge will suffice? https://www.harborfreight.com/fuel-i...ter-62623.html
Amazing what $14.97 will get you at Harbor Freight.
Thanks for your invaluable advice! I'm grateful for your help Hoonk.
keaunym
Mar 28, 2009 08:50 AM
kirks_volvo
Nov 12, 2008 07:53 PM
cbrack
Jul 27, 2008 10:55 AM
agr1093
Oct 5, 2007 02:33 PM
edisonbelle
Apr 19, 2005 06:00 PM
