Need HELP removing '03 V40 fuel filter
Old Mar 27, 2009 | 10:39 PM
keaunym's Avatar
Default Need HELP removing '03 V40 fuel filter
I'm having trouble removing the fuel filter on my '03 V40. The side that requires a special tool was easy enough with a plastic putty knife I cut a square notch in, but the other side that has two blue square push-buttons won't release the filter. I can rotate the filter along its axis (so it is not stuck), and I know the buttons are pushed in all the way when I try to pull it off... since I wasn't sure if my fingers were pushing the buttons in all the way (since the buttons are flush) I modified a pair of pliers to push the buttons in for me, but that didn't help any. I have a feeling if I use any more force than I have, i'll end up breaking the thing, and the funny thing is, at Volvo parts they can't figure out from the schematics what that piece of fuel line is, so I better not break it since the part apparently does not exist for me to replace it!
Any tricks? First thing I did before anything was spray it with triflow to loosen things up, so I've already tried the penetrating oil trick.
Thanks in advance.
Old Mar 28, 2009 | 08:50 AM
Very strange. They usually come right off. I use my fingers and press the buttons in and pull the filter out.
AA752
Mar 28, 2014 09:33 PM
oreng
Mar 20, 2014 01:22 PM
clt750
Aug 3, 2013 10:23 AM
axelm
Nov 6, 2008 04:31 PM
