2002 S80 Dome light problem
Old Aug 14, 2017 | 09:34 PM
rb61's Avatar
Default 2002 S80 Dome light problem
New to forum. New to Volvo
Car new to me- Dome light stays on until door is locked from outside.
Am I simply missing something?
If there is a switch that is set incorrectly, that would be great.
If there is a fix, please let me know.
If there is not an answer, can I pull a fuse or remove dome light bulbs for now?
I know I will forget to lock door and end up with a dead battery.
Thanks for any help that you can provide.
Ray
Old Aug 15, 2017 | 09:40 PM
rb61's Avatar
Default interior lights not turning off when door closed
I see that a large percentage of posts have no replies, so I thought I would add what I have found.
If I push and hold the dome light button for 3-4 seconds, it stays off (Owner's manual) At least someone could have mentioned this temporary fix to a new guy to both Volvos and this forum..
The door edge lights still do not turn off when door is closed- unless the door is closed with some force.
It seems that the correct fix is replacing the door locking mechanism. There is at least one (non replaceable) micro switch in the door locking unit that is probably bad.
s80kid
Jan 22, 2011 11:12 AM
manuel
Jan 14, 2009 05:42 AM
ikey
Dec 15, 2008 06:05 PM
xjflexer
Jul 2, 2007 05:45 PM
volvobacon
Sep 30, 2005 09:25 PM
