2003 xc70 no turbo boost
Old Sep 1, 2021 | 10:24 PM
dogvolvo's Avatar
Thumbs up 2003 xc70 no turbo boost
my just purchased volvo xc70 shows -10.5 on diagnostics for boost pressure
had it diagnosed as leaky actuator diaphram !!
no smoke out exhaust in neutral revs up OK
would leaky actuator give me no turbo
also checked actuator manual operation its got resistance pushing away which means its closed i think
can you point me in the right direction
Old Sep 2, 2021 | 08:24 AM
Dingus's Avatar
If you had an issue with the actuator I would think you would get overboost since the waste gate wouldn't be able to open properly. Vacuum is fine and expected in idle, and 0-low throttle conditions. Is the car driving fine or are you getting the car check for an issue?
Old Sep 2, 2021 | 03:43 PM
dogvolvo's Avatar
thanks for replying the car drives as normal like a car without a turbo if you say wastegate closed due to faulty diaphram
then either the turbo is seized so its not spinning do you have any posts on removal and installation of turbo
Old Sep 3, 2021 | 07:02 AM
Dingus's Avatar
I wouldn't go that far just yet. No check engine lights or anything? Also what is that -10.5 value you are giving? Did you take it to a good volvo shop or dealer to get it diagnosed? If you had bad boost pressure you would get some codes in VIDA whether you had CEL or not.
Old Sep 3, 2021 | 02:55 PM
dogvolvo's Avatar
hi, diagnosed at volvo workshop as leaky diaphram
they suggest replace turbo engine has been serviced for the last 10 years 225ks on clock
i put my torque app and bluetooth adaptor to read the data
on boost it showed minus 10.5 when increased the revs it didnt move
possibly the car needs to be in auto so the boost works ??
no alarms
Old Sep 8, 2021 | 10:43 AM
Dingus's Avatar
You need to be in drive to gain any boost. Boost is limited in 1st and 2nd, but you'll see a change in pressure in 2nd if its working properly. If its a leaky diaphragm it can be replaced without doing the entire turbo.
Old Sep 8, 2021 | 03:16 PM
dogvolvo's Avatar
thankyou what worries me is that if theres no vaccum on the actuator side and we have tcv and turbo solenoid connected to that side of wastegate with vaccum hoses wounld that be the reason
there no signal so the boost is not comming on ? another commemt is the wastegate actuator seems to be closed !!
i put hand on it and there is pressure on the rod i am pushing the rod away from actuator
surly if the actuator is shut we can have boost if turbo is still working ?
noticed theres oil on the cold side of turbo sittng on the housing looks like leaking oil from above
longbeach
Oct 12, 2020 10:37 AM
import47
2001-2013 model year V70
May 5, 2016 09:54 AM
pete000
Aug 26, 2010 12:45 PM
dannydoo
Oct 17, 2006 04:08 AM
driftin V
Jun 2, 2006 10:47 PM
