2004 V-70 transmission sudden downshifts
Old Mar 14, 2012 | 07:23 PM
David Roche's Avatar
Question 2004 V-70 transmission sudden downshifts
2004 V-70 AWD has an unintended downshift at highway speed. Occurs mostly in wet weather after sustained (3 hours) of driving. Occurance is a loud drivetrain BANG, momentary deceleration, and RPM needle jumps about 500/1000 RPM. Duration of event is less than 1 second and transmission reverts to 5th gear. Information display says LEFT REAR PASSENGER DOOR OPEN, followed by SRS AIRBAG NEEDS SERVICE, followed by ABS BRAKE FAILURE STOP SAFELY. Event will re-occur within 3 to 5 miles. Stopping and shutting off engine resets whatever the cause was and leaves the SRS AIRBAG NEEDS SERVICE on the info display. Message cannot be cleared. Diagnostics (3 times) show nothing.
First event at 88,300. Has occured 3 more times after that about every 3000 miles under the same conditions. V70 has been same dealer serviced since new. Nothing has been neglected that needed repair or replacement including a $1,200 instrument cluster replacement at 94K. The 3rd event was able to get the car diagnosed before the engine was turned off. It was referred to by the Volvo dealer as and active event. DCM also failed at that time. They just shrug their shoulders when they haven't found the cause.
Dave R
David Roche
2001-2013 model year V70
Dec 2, 2013 02:26 PM
RA082324
Sep 15, 2013 09:44 PM
cliffocd
Mar 23, 2012 05:03 PM
3nikki
Dec 29, 2011 01:43 PM
1953NAA
Jun 28, 2009 04:28 PM
