2004 Volvo ABS
Old Oct 23, 2019 | 06:56 AM
Vtoad's Avatar
Default 2004 Volvo ABS
I have a 2004 Volvo XC 70 the ABS light is on And has multiple problems I have done a lot of reading they say it’s the ABS unit . And have it rebuilt but that doesn’t always fix the problem I appreciate the help I live in Minnesota
Old Oct 23, 2019 | 09:05 AM
You need to have the diagnostic codes scanned for the ABS - not all scanners will read them but the codes will tell you what set off the light. Could be a wheel sensor, could be the ABS pump, could be the ABS controller board has developed cracks in the solder and needs to be rebuilt. Any other symptoms like a flashing TRACs light or does the ABS light come on with the key or come on when you start driving and touch the brakes?
Old Oct 23, 2019 | 09:52 AM
Vtoad's Avatar
Default Vtoad
Thank you for your quick response the DSTC light is on the trip odometer does not work cruise control does not work I have replaced the neutral safety switch the ABS light is on on the dash I don’t think that the traction control system is working
Old Oct 23, 2019 | 09:53 AM
Vtoad's Avatar
Default Vtoad
I have not checked the wheel sensors I will have to do that and get back to you thanks for the info
GuySurname
May 12, 2017 03:31 PM
MissSpentYouth
2001-2013 model year V70
Mar 11, 2017 06:09 AM
zx1200ninja
Jun 11, 2012 07:06 PM
zx1200ninja
Jun 11, 2012 05:43 PM
tr_car_nut
Aug 5, 2008 08:59 PM
