2005 s60 first key fob dontrespond then wont leave N-D
Old Mar 10, 2026 | 07:35 PM
Gdonkey's Avatar
Default 2005 s60 first key fob dontrespond then wont leave N-D
I know that this would usually be a shifter problem but started wiht keyfob not opening trunk then 20 minuted later it did. when i arrive to store i try to park and as it reverse lockout from security. O cant remove key but when i got home i tired other keyfob also. keyfobs wont unlock or lock doors activate alam anything. i can lock the doors manually by key or bt using door switch but i cannot get out of neutral or drive and cant remove key. I am onON position so last i remember is that you can still use keyfob to unlock or lock dorr while running. My wonder if it is acting as. lockout so it thinks i am in park and wont allow to shift. it seems if this was a lodged pin in shifer or such tht my keyfobs would work. as said before the keyfob didnt respond when i was parked with engine off and would not unlock trunk. i then went back to bank didnt lock car. came back 20 minutes later keyfob worked and unlucked trunk and could lock unock. ithen went to grocerystore again 10 minutes later and coul not park.
thanks for anyhelp before i tear into shifter bocy then cant get out of park to get to mechanic
Recharge
Oct 22, 2022 02:46 AM
ChuckB
Jun 1, 2020 05:56 PM
buddlejr
Dec 3, 2012 06:08 AM
phils94850
Feb 16, 2010 12:21 PM
mschenkel
Dec 29, 2009 04:05 PM
