2005 xc90 warning light no fault codes
Hello I just bought this used 2005 xc90 and the red triangle warning light comes on with no fault codes took it 2 different places to have it put on the scanner and no codes come up?? they tell me not to worry about it. Any clue what it could be I did put a new battery in couple weeks ago
It depends on the message and scanner. For example, a low coolant light will give a red triangle and a warning in the text display but will not set a fault code. Or if there is a fault code but they are using a cheap scanner that can't communicate with all systems, they won't be able to read it.
