2007 Volvo s60 2.5L pistons
Old Jan 14, 2026 | 05:40 PM
jakemfradis's Avatar
Default 2007 Volvo s60 2.5L pistons
Had someone do timing belt on the car they messed up timing valve slap on every piston didn’t start up only cranked can I just replace the pistons or do I need to do connecting rods and valves?
Old Jan 14, 2026 | 06:05 PM
If the timing belt was installed incorrectly - enough to where the valves hit the pistons - you will simply have bent valves. There won't be any connecting rod or piston damage (other than some small marks on the tops of the pistons.)
Old Jan 14, 2026 | 07:16 PM
The dents in your photos on your pistons - Saw those maybe 60 times on engines timing belts came off while running. Simply had the machine shop I use do a valve job, replacing usually all 20 valves (or 16/24 with the 4/6 cylinders), sometimes guide replacement was needed. The hard part is adjusting the valves - so we left that up to a machine shop.
Some may suggest smoothing out the dents to prevent hotspots. But we usually just left them alone.
Old Mar 16, 2026 | 12:21 PM
Default Exhaust camshaft
Thank you for your recommendations definitely saved me some money and time is there any other way to contact you like email I have a video I’d like you to take a look at but I can’t upload it here it seems like my camshaft is bent when I look it up doesn’t seem like that happens to people so If you could take a look at a video I made that would be awesome thank you!
lcollinward
Oct 20, 2025 06:11 PM
Ainars Vasiljevs
Oct 4, 2019 07:40 AM
Jeraii
2001-2013 model year V70
Apr 23, 2017 02:07 PM
RK Volvo
Oct 7, 2010 03:18 PM
tberiau
Aug 10, 2010 03:51 PM
