87 740turbo stalls at lights/sputters
Old Nov 6, 2008 | 03:13 PM
jdarlin1's Avatar
Default 87 740turbo stalls at lights/sputters
hi.
i have an 87 volvo 740 turbo.
for the past three months, it has been giving me issues when coming out of idle.
the problem occurs after warmed up, and after sitting at 5 or so stop lights.
when i give it gas after sitting in idle for a while, it is as if there is no response for a second or two, the car kind of cuts out (and it gradually gets worse as i drive more).
once it begins doing this, it starts to stall out when sitting in idle for half a minute or so. (it will sputter, and when i give it gas it either A) kicks back in or B) there is absolutely no response and it sputters and dies) the longer i drive it for, the worse it gets, and eventually it dies and doesnt start.
i had the external fuel pump changed about a year ago, and it has always whined (sometimes louder than the engine itself).
when the car begins to sputter the fuel pump will whine louder.
also, when sitting in idle the gas gauge will read less, up to half a tank.
after i give it gas (and if it doesnt stall), it will cut out and then start going and the gauge will go back to normal.
its been doing this for about three months, gradually getting worse and worse.
now it doesnt last more than five minutes
ive replaced the fuel filter, temp sensor, and main fuel pump (and it still whines).
today im going to look at the in tank pump, but seeing as im pretty mechanically incompetent i dont know what to look for.
unfortunately im a poor college student so this stuff hurts >.<
Old Nov 6, 2008 | 03:32 PM
TIPSP's Avatar
Got Boost?
Default RE: 87 740turbo stalls at lights/sputters
Welcome...
When was the last tune up?
Which temp sensor was replaced?
There is an in-tank fuel pump also check that.
Old Nov 6, 2008 | 04:45 PM
jdarlin1's Avatar
it was located on the side of the engine block underneath the throttle body. sort of.
there is another one elsewhere?
the plugs/wires were replaced about three months ago, the distributer and coil were both replaced about a year ago.
does that qualify as a tuneup? like i said, im mechanically incompetent. (the haynes manual is almost latin.)
the car sat around in my moms garage for 11 years. it started no problem.
but i had to have the fuel injectors replaced w/in a week.
the local volvo mechanic thinks my gas tank is rusting from the inside out. i cant afford to replace that unfortunately.
my grandpa thinks its the fuel regulator? today i paid attention to the external fuel pump, and i noticed three things while playing with it.
when i first start the car, it does not whine at all. it takes a few minutes.
when i hold it, it still whines. so its not a vibration.
the whines pitch gets higher when the car is about to die.
it only takes it about five minutes.
and ideas?
Old Nov 6, 2008 | 05:24 PM
air force rascal's Avatar
When was the last time you checked the Fuel Filter...?
Old Nov 6, 2008 | 06:04 PM
TIPSP's Avatar
Got Boost?
I would probably do a tune up real soon...
Here is a list of the Engine sensors, and some info on them: http://www.vcoa.org/700-900-faq/EngineSensors.html
Sounds like you already replaced the ECT...
Check this link for fuel issues: http://www.vcoa.org/700-900-faq/EngineFuelinjection.html#RelievingFuelPressureWhen OpeningFISystem
Is your check engine light on? To check the codes...you need to find this box.
This site tells you how to pull the codes: http://www.troublecodes.net/Volvo/
Tech will be able to assist you furthur.
Old Nov 6, 2008 | 07:37 PM
jdarlin1's Avatar
no check engine light yet... >.<
im going to check those links now.
thanks a bunch =)
Old Nov 6, 2008 | 09:00 PM
TIPSP's Avatar
Got Boost?
Yep. also check the relays.
those links should have everything in there to help you check stuff.
Old Nov 7, 2008 | 11:30 PM
jdarlin1's Avatar
im really sad to say it, but i broke it.
the sending unit for the intank fuel pump. the car sat for a pretty long time and everything is rusting out.
the breather hose snapped off.
im a poor college student. i cant afford it all the repairs and expensive parts... so im storing it for now >.<
thanks for the help! (the problem was the intank pump...)
ill be back on here in the summer =)
justin
Old Nov 7, 2008 | 11:38 PM
TIPSP's Avatar
Got Boost?
Ouch...that sucks.
well there are some good sites that have parts cheap..
http://www.fcpgroton.com/or http://pelicanparts.com/or http://ipdusa.com/
Good luck and i now how it feels to be a poor college student. '
EDIT: don't forget to check out local junkyards. the car was in storage that whole time?
how many miles you go on that thing? any pics.
BennyMG
Jun 22, 2011 01:55 PM
Caseyface
Sep 28, 2010 08:02 PM
cc2times
Sep 12, 2009 03:18 AM
jitruax
Oct 5, 2008 08:47 AM
keith
May 8, 2007 05:01 PM
