93 850 glt
Old Jul 12, 2010 | 05:08 PM
MY93-850GLT's Avatar
Default 93 850 glt
I HAVE A 1993 VOLVO 850 GLT WITH 199,400 MILES. I JUST REPLACED THE BATTERY. I DROVE IT TO MY DADS HOUSE. I REPLACED THE FRONT DIRECTIONALS AND REWIRED THEM. THEY WORK FINE. THE PROBLEM IS THAT THE CAR WILL NOT START NOW, I HAVE CHECKED EVERYTHING I KNOW OF. THE CAR WILL NOT EVEN TURN OVER NOTHING. I DID NOTICE THAT AT ONE POINT WHEN MY DAD MOVED THE WIRING HARNESS FOR THEW HEAD LAMPS I LOST ALL LIGHTS ON THE PANEL??? ANY IDEAS WHAT WILL FIX THIS PROBLEM OF NOT STARTING???
THANKS,
AL
Old Jul 15, 2010 | 06:09 AM
ibanez958's Avatar
try to boost the car first, if it start, mostly likely u need an alternator
Old Jul 29, 2010 | 08:05 AM
maha654's Avatar
So I went out to start my Volvo today, It's been sitting for about three months. It started and ran horribly for about three seconds, then shut off. When I went to restart, the motor just spun (sounded like absolutely no compression). I'm about to check the timing belt, but before I do can someone tell me if this is an interference motor? Can I just do a t-belt job on it and be good, or do I have the chance for some bent valves? It's a non turbo.
__________________________________________________ _______
neon clocks Personalized Tote Bags
Old Jul 29, 2010 | 06:38 PM
You really should start a new thread. Anyway, yes they are interference motors. However, if you were not driving the car or reving the engine, there is a chance that you did not damage valves, etc. But try not to cross a bridge before it has been built. Check the t-belt 1st.
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
matt01
May 15, 2011 07:58 AM
gentlejax2
Apr 15, 2011 10:21 AM
squiz
May 12, 2010 03:27 PM
VolvoSwede
Aug 9, 2009 08:12 PM
