97 V90 Seats
Old Jul 9, 2008 | 07:24 PM
kellygrantham's Avatar
Default 97 V90 Seats
Is there an easy fix for my front seats? Only one side of each seat will move up or back...i.e. they act like they swivel and I'm tired of eating my knee caps.
Old Jul 13, 2008 | 06:06 PM
wyobear's Avatar
Default RE: 97 V90 Seats
My 1998 S-90 had the same problem. Disconnect the neg battery terminal,unplug the electrical, remove the seat screws and lift out the seat. The motor that controls the forward, aft movement does so by cables. The longer one (inboard) is not seating in the motor and this causes the seat to skew on the track. Remove the two screws holding the cable clip on each end and pull out the cable asseembly. Cut off the retaining clip. Push out the cut offplastic in the clip with a wooden dowel, reinsertthe clip on the plastic and reassemble the cable and screws. You have shortened the plastic housing thereby lengthening the cable. Realign the seat tracks. It works! The cost is ZERO!
Old Jul 13, 2008 | 08:52 PM
Or you can heat up the Metal sleeve end of the cable and slide the plastic part in more doing the same thing.
martin calva
Apr 15, 2015 04:59 PM
EastCoastVO
Feb 12, 2015 07:18 PM
olgol
Jun 9, 2010 12:58 PM
olgol
Jun 9, 2010 11:40 AM
tomservo
Interior
May 1, 2008 05:31 PM
