98 850 pressure and exaust problems
Old Feb 16, 2014 | 07:33 PM
marshall319's Avatar
Default 98 850 pressure and exaust problems
Hello I recently replaced the pcv system in the hopes that I could correct the pressure in my motor ie: smoke in the dip stick and out the oil cap It was my understanding that there is supposed to be a vaccume when you accelerate? I could be wrong tho anyway, The next thing is smoke frommy exaust it intermittant and only does it occasionally at idleing speed and a little at about 60 i just changed my plugs wires cap and rotor, I am also curious if it has to do with the egr valve, idk I'm all over the place with this hope someone can help
Old Feb 16, 2014 | 07:48 PM
RGuy's Avatar
Standing in front of your engine remove the throttle cable cover. Below that in the upper front of the engine on the right you will see two vacuum lines. Remove those and test to see if they are plugged up. You can trace the hoses and see if all is good.
Old Feb 16, 2014 | 07:55 PM
RGuy's Avatar
At the bottom of the big fat hose coming from your Mass air sensor there is a pop out valve that needs to be checked you will see a vacuum line going into it. It is easy to remove and clean but a bear to put back on. You can spray throttle body cleaner in it without removing it. What condition is your turbo in? Turbo or not I ended up replacing all my related vacuum lines in the engine if my 850.
Old Feb 17, 2014 | 12:08 PM
I will trace hoses thank you. I believe my throttle cable cover is missing but I think your talking
About the white and black line?
Old Feb 17, 2014 | 12:13 PM
Thanks for your response I have time today I'm going to check, my turbo is in good condition I had my guy look at it when he helped me with my pcv.
DunnaliCustoms
Jan 27, 2009 03:23 PM
Riculus
May 14, 2008 07:53 AM
Pv12345
Oct 11, 2007 08:33 AM
HelgaTheS80
Mar 23, 2007 03:57 PM
colgate41
Apr 7, 2006 03:25 PM
