Bad Battery?
Old Aug 12, 2008 | 08:10 PM
GreenBrick's Avatar
Default Bad Battery?
My battery sometimes holds a charge, sometimes doesn't. The charging system works fine - plenty of voltage to charge the battery, and it does.
I checked the battery voltage tonight - 10 volts. It couldn't even snap the solenoid, let alone crank the engine. I put the charger on it for about a minute before (for grins), I take it off and check the voltage - it read 12.5 volts. Mind you, the charger didn't indicate full charge.
I'm thinking I've got a bad cell in the old (5 years old) battery. After fully charging it another day, I held my meter on it while the voltage steadily dropped several volts in a few minutes (it seemed).
I've got the charger on it now. I'll let it charge for an hour or so and check it again.
Old Aug 12, 2008 | 09:49 PM
Default RE: Bad Battery?
I would say bad cell.
Old Aug 18, 2008 | 07:51 PM
GreenBrick's Avatar
Default RE: Bad Battery - YES, it was
I replaced the battery with a new one, and no more problems.
86volvoguy
Apr 20, 2017 10:50 PM
jclark5093
Nov 21, 2010 08:28 AM
flippyflipz
Dec 2, 2008 01:52 PM
02VolvoS40
Feb 4, 2008 06:05 PM
