Bad Vibrations
Old Oct 8, 2010 | 09:52 PM
Soundbyte's Avatar
Default Bad Vibrations
Hello:
I have a 1998 V70 AWD with 117,00 miles. I just had the drive shaft removed to send it out for rebuilding. The car is now a front wheel drive. After it was removed, I am getting a very nasty vibration when I hit 30 mph. This was not happening before it was removed. It seems to level off after 45 mph. I can't pin point the source of the vibration, but it seems to be under the drivers seat. It kind of feels like one of those vibrating message chairs. The entire car shakes. Any thoughts would be helpful before I take it back to the mechanic.
Rich
Old Oct 11, 2010 | 05:29 PM
aircraftnut's Avatar
was it removed all the way up to the transfer case? Im going through a similar problem i loosened the driveshaft hanger bearing to tryand remove the shaft. When i put it back together the car shakes from 40-45mph someone told me that you have to make sure the hanger bearing which is in the middle of the two piece shaft is straight or it will be out of balance. Hope this helps.
earlswrench
Dec 29, 2011 05:09 PM
35mm
Dec 6, 2011 12:33 PM
white83glt
Mar 16, 2011 04:24 AM
Soundbyte
Oct 8, 2010 10:56 PM
99S80DFW
Feb 20, 2009 04:57 PM
