Bad Vibrations...
Old Dec 30, 2008 | 12:31 PM
99S80DFW's Avatar
Default Bad Vibrations...
OK, so I already know I need shocks & struts and I discovered recently that my upper engine mount is broken (bushing is seperated). I got a new engine mount today and plan to replaceit tonight. The shocks/struts are more money than I have unfortunately. I need to know if the horrible vibrationsare related to these issues or if there is an additional problem(s) that need to be addressed as well.
Somewhere between 45-70 mph (not always, just random) the car will start a violent vibration that feels more like an almost flat tire than anything else (no - my tires are fine). It will go away completely if I let off the gas but as soon as I press the gas pedal again it starts back up. After a while it will just go away. It rarely happens if I'm in the car by myself but if I have1 or morepassengers it's guaranteed to happen.
I'm scared to death I'm going to lose a wheel or something but this car is my only transportation right now. Please any and all suggestions are welcome.
Old Dec 30, 2008 | 01:00 PM
gordon368's Avatar
Default RE: Bad Vibrations...
I had something like that happen to me, turns out I had a bent rim.
Old Dec 30, 2008 | 06:42 PM
duwash1's Avatar
99 Volvo S80 T6 100k miles
Same issue and took it to the dealer for a look.
New tires, balancing, 4 wheel alignment and still there. Dealer looker further and said the CV joints have some play in them. Just bought the replacment passenger side one from www.eeuroparts.com for about $100. You can find some good directions for DIY job inside the S80 posts.
I'm going to tackle later this week and I'll post an update
Old Jan 2, 2009 | 10:44 AM
duwash1's Avatar
Easy as pie. Just check the passenger side for that Visco clutch option. Mine had it and I did order the right one. The tell tale sign is another item behind the 2nd CV joint before the axle enters the transmission.
Dumbly put, it looks like there are 3 CV joints instead of two. If you have this, you have the Visco clutch.
Directions were excellent here http://www.matthewsvolvosite.com/for...ic.php?p=63174 just some bolt sizes being 1 size off. Otherwise an easy job that took 1 1/2 with 2 guys
Vibration all gone. Runs so good I may do the drivers side now!
Old Feb 19, 2009 | 10:10 AM
Xkontour98's Avatar
To the OP. What did you end up finding ou about your car? I have the same vibration issues, occurance/speed/passengers/etc. I am thinking I need to replace the passenger side axle but wanted to see if that was your case before I order one up.
Old Feb 20, 2009 | 04:57 PM
99S80DFW's Avatar
Sorry for not updating.
I replaced the upper engine mount and most of the vibration went away. Now it only vibrates under hard acceleration. I will be checking the CV joints next.
earlswrench
Dec 29, 2011 05:09 PM
35mm
Dec 6, 2011 12:33 PM
white83glt
Mar 16, 2011 04:24 AM
Soundbyte
Oct 11, 2010 05:29 PM
Soundbyte
Oct 8, 2010 10:56 PM
