Better headlights for my XC70
Old Nov 13, 2008 | 07:09 AM
2002XC70's Avatar
Default Better headlights for my XC70
My 2002 XC70 healights suck! I have installed Sylvania Silverstar Ultra Vision lamps in all the lamps up fronthigh beam and low beam. While they are really white lights, the low beams just don't light up the road like my 2005 Subaru Outback. The high beams are great, but driving on back roads with low beams on (due to oncoming traffic), they just don't have the light coverage. So are there some alternatives out there to replace what I have i.e. HID aftermarket etc.? Thanks.
Old Nov 13, 2008 | 07:37 AM
S70driver's Avatar
Default RE: Better headlights for my XC70
As far as actual lenses, none that I know of.
As far as HID's go, yes buy them. Worth every penny spent and to be honest HID's can be had for $100 and that is for a good set too.
Buy your HID's from SharpHID.com John will take good care of you.
I have an Apexcone 35w system from him and it works wonderfully and looks great too. The light output (Lumens) is far above any Halogen bulb can produce.
And the install is simple and takes like 15 minutes per side. Not much modification is needed, other then drilling a small hole in the back of the LOW beam caps so the wires can pass through. And a gasket will seal up the the hole.
Old Nov 13, 2008 | 07:39 AM
S70driver's Avatar
FYI 4500k-5000k will net you the best and mostlight output (LUMENS). Anything above 5000k and all you get is a color change and actually you will get less light output (LUMENS).
3000k can be used for foglights.
Old Nov 19, 2008 | 01:58 PM
2002XC70's Avatar
ORIGINAL: S70driver
Thanks, I will check out this site and see what they have. (:
Hanafi
2001-2013 model year XC70
Oct 13, 2013 05:05 PM
phil.crawford1
Dec 31, 2011 07:15 PM
VDriver24093
Feb 21, 2011 04:35 PM
S60T5
Dec 30, 2005 04:05 AM
