Cam locking tool fabrication
Thank you so much for this writeup, could someone answer a few questions for me about it though?
I have a 94 850 turbo with no markings on the cams, during my mechanics repair of the head gasket, after removing the cams, the crank spun, and with no marks on the crank, they were stumped how to get it timed, they have given up, and I am going to attempt to time it back, will this tool allow it to be timed incorectly? Or if I use it, it will always be in time? I just am a bit confused, if someone could please explain what they would do to get my car back in time?
Watch this
Watch it all because this guy is pretty dang good mechanic even though he isn't focused only on volvos. I'm prepping for the same headjob as well and getting my tools and parts in order.
Last edited by Arlie98s70; Jun 20, 2013 at 02:47 PM. Reason: add applicable context reference
it is quite helpful in getting it right and appreciate the share and the find as it is ok that each an everything is available on you tube yet falling on the desired shows is not always an easy task
Tevida Side Effects
Tevida Side Effects
Attachment 2089
Attachment 2090
Hold the bent vertical in the cam slot, mark and cut. Then hold the cut piece in the cam slot and mark a hole location that will allow a screw to attach the horizontal to the vertical. Because the stock is only 1" attention needs to paid to the screw heads. see pic from back side.
Attachment 2091
Drill hole in the vertical and use it to mark a hole in the horizontal.
Attachment 2092
yes... this motor was beeding big(BIG) time from it's cam seals. I can't wait to measure the cylinders.
Bolt the verticals to the horizontal with 10-32 or 10-24 and tighten every thing up. Worked well for me... hope it helps.
Gabe, don't build one(unless you really want to) I'll send you the one I made for the write up. An early graduation gift, just PM your shipping address. Yeah I still need those parts so I'll PM you.
PS... I almost forgot. another simple tool I made to remove the aux./serpintine belt. 10-24 screws in aluminum angle bought at Home Depot. Use washers though and tighten the screws well.
Attachment 2093
Bobec
Attachment 2090
Attachment 2091
Attachment 2092
Attachment 2093
Bobec
I just did the cam seals on our 01 V70 and had to make a tool from steel. Even 1/8" cold rolled steel will bend. 1/4" will not fit in the cam slot. I used the 1/8" anyway and was able to get it back together right. Next time though I will heat treat the 1/8" CRS using a MAP gas torch. Heat to cherry red and quench in water then temper should keep it from bending.
If you're doing cam seals keep in mind the two front seals are different. I found this out after I got the sprockets off and did not have the right seal for the VVT side. Fortunately O'Reilly sells and had in stock the front seal KIT. IMO the front seals should always be sold in kits.
I really don't understand why everyone wants to hack together the proper tool for the job. The correct tool is relatively inexpensive and works perfectly. In addition, you get a great cylinder head cover installation tool all included in one.
https://www.ebay.com/itm/Volvo-Crank...gAAOSwhilZamQz
